Modelling Heat Transfer in a Moving Solid Bed |
Krishna Patel
Rep Power: 0 ![]() |
Hi, I was looking for some suitable software to model the heat transfer between solid particles and a flue gas for the case described below. I am a novice with Fluent and only currently familiar with the basic features.
The solid particles are pine wood, assumed to be spheres of 3.5mm, where they form a moving solid bed (non-fluidized) under gravity. The heat is transferred from a hot flue gas, indirectly, through shells/pipes of different geometries, as shown in the attached image. I would like to visualise the behaviour in terms of temperature and velocity profiles. If the modelling of the moving bed is difficult, it can be assumed that the movement of the solid bed is very slow, allowing the particles to be modelled as static instead. I would also appreciate any guidelines / recommendations on setting up a procedure for this model. Kind Regards |
heat transfer, moving bed, solid particles |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Heat Transfer from Solid to Adjacent Solid and then to Adjacent Fluid | dkx209 | FLUENT | 1 | July 18, 2013 09:50 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
Conjugate Heat Transfer between fluid and solid | Li Yang | Main CFD Forum | 8 | March 27, 2004 11:05 |
