Divergence Problem Conjugated Heat Transfer
Like Tree1Likes
Old   November 27, 2017, 07:08
Christoph Hahn
Christoph.Ha is on a distinguished road
The think is, i also want to get the surface temperatures of the solid housing. So it would be necessary to make a simulation with fluid and solid part.
Christoph.Ha is offline   Reply With Quote
Old   November 27, 2017, 07:54
Moritz Kuhn
MKuhn is on a distinguished road
In my opinion you will get nearly the same results without solid mesh and wall thickness+shell conduction instead. Which is the thermal condition on your outer wall? (Heat flux, fixed temperature or convection?)
MKuhn is offline   Reply With Quote
Old   November 27, 2017, 09:38
Christoph Hahn
Its a heat flux, but coupled with a heat generation rate inside an electrical componend which is coupled to the wall. In an later step i want to model this electircal componend also, therefore i think i need that wall physically?
Old   November 27, 2017, 10:36
Moritz Kuhn
You can also impose a heat load (Heat Generation Rate in w/m³) to a shell conduction layer. Please refer to here and here.
Old   November 27, 2017, 20:54
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
Originally Posted by Christoph.Ha View Post
i have some news. Today i tested an setup without the solid wall, so just the fluid domain. That converged very well and max. Velocitys are <10m/s (with an inlet Velocity of 5m/s). So i think there must be something wrong with the interface.
During initialization i get following info: "Info: Interface zones overlap for mesh interface contact_region.
This could adversely affect your solution."
After some research i found out, that the walls of both domains have some issus with the contact definition. But i´m not aware of how i could solve that issue, does anybody of you guys can tell me how to fix it?
Thanks in advance,
Christoph
EDIT: Mesh -> Contacts -> Contact Region shows Contact: 686 Faces, Target: 687 Faces. Scoping Method is Geometry Selection.
I think, for your case you do not need contacts.
Delete them before loading mesh into fluent. In case you are using ansys mesher go to mesh -> contacts -> delete contacts.
Than load mesh into fluent, define materials for solid and fluid parts.
use
mesh m-z s-i-b
This will create shadows between solids, in case you have more than one.
Best regards
AlexanderZ is offline   Reply With Quote
Old   November 29, 2017, 07:32
Ovid
Fole is on a distinguished road
If I were you:
1) Change to kwSST standard (no transition). Because y+=1 is a must in that model.
2) Check y+ and BL resolution. If after reducing speed your model converged, maybe it is the cause.
3) In my experience, inflation on complex geometries, I limit the transition ratio even more (limiting the height), and then adaptive mesh refinement during solution. ICEM CFD is another solution, I am on the way.
Fole is offline   Reply With Quote
Old   December 5, 2017, 02:43
Christoph Hahn
Hello Guys,
i found the problem!
It was a problem with the interface between the fluid and the solid wall!
I solved it with a mapped (+coupled) interface between those domains. No it converges very well with k-e-model and energy equation!
Thank you all very much, i still learned a lot about troubleshooting with fluent divergence!
Best Regards,
Christoph
Old   December 5, 2017, 11:46
Moritz Kuhn
Hi Christoph,
thanks for your reply, fine that its works now
Moritz
amg solver, convergence, divergence, fluent, omega
fluent conjugate heat transfer problem eling FLUENT 9 October 21, 2017 11:10
CFD analysis of a heat transfer problem vinitraj3 Main CFD Forum 0 May 2, 2015 06:35
heat transfer validation problem messbalint CFX 4 March 31, 2012 17:14
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 23:22
regarding B.C. of Heat transfer problem Manoj Padmakarrao Raut Siemens 0 March 17, 2005 01:01
