Two Phase Flow Though Vertical Pipe - Diverging
Old   November 5, 2017, 18:49
Default Two Phase Flow Though Vertical Pipe - Diverging
Stone preston
stonepreston is on a distinguished road
I am trying to model a two phase flow of saturated liquid through a vertical pipe with constant heat flux at the wall.
I have modeled it as a 2d axisymmetric problem. I first did a single phase turbulent model and then exported the outlet profile and used that profile as the inlet boundary conditions. I was basing my work off this tutorial here:
https://www.researchgate.net/file.Po...01466537647654
However, my solution is diverging after 4 or 5 iterations. I am not sure how to make this work.
my workbench files are available here if anyone can take a look (I was using workbkench version 18.2):
https://www.dropbox.com/sh/bi1147n97...X0ApKPToa?dl=0
I have a few different models there, the one I am most interested in getting to work is the saturated 2 phase one.
I have been stuck here for a long time and nothing I do seems to help.
Problem statement:
A vertical steel tube carries water at a pressure of 10 bars. Saturated liquid water is pumped into the D= 0.1 m diameter tube at its bottom end mean velocity of 0.05 m/s.
The tube is exposed to combusting pulverized coal, providing a uniform heat flux of 100,000 W/m2. Length of the tube is 30 m
stonepreston is offline   Reply With Quote
Old   August 27, 2018, 12:17
Default Vertical pipe flow
Hamed Abdul Majeed
hamed.majeed is on a distinguished road
Hey.
I am interested to help in the problem on vertical pipe flow. I have a lot of question as to how you initialize the solution and the BC you setup!
Your files don't open. If you need help get back to me. Thank you.
Regards
H.
hamed.majeed is offline   Reply With Quote
Old   August 27, 2018, 12:45
Stone preston
Do you have an email address I can reach you at Hameed?
Old   August 27, 2018, 14:14
Stone preston
Unfortunately I no longer have the files. I can remake them if you need. I can also provide you with a report that details everything I did on the case. Never did get it working though but if you look through the report you might see somewhere I went wrong. Let me know an email address I can reach you at and I will email you the report
boiling flow, fluent, two phase
Two Phase Flow In Vertical Pipe stonepreston FLUENT 2 October 31, 2017 09:35
two phase air-water vertical pipe hasan-hasani FLUENT 3 March 25, 2009 04:53
HOMOGENEOUS TWO PHASE FLOW IN A PIPE beginner FLUENT 2 July 27, 2007 13:17
How to adapt lower phase in 3 D pipe flow K.Baker FLUENT 2 July 21, 2007 16:19
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
