Effect of modified gravitational acceleration (g) on Natural convection results |
vidyadhar
Rep Power: 10 ![]() |
I am simulating natural convection problem in Fluent- vertical plate with fins (conjugate heat transfer problem). To achieve different Rayleigh numbers, I am modifying acceleration due to gravity, by keeping other parameters constant. 1. How to assess the results such as Nusselt number, heat transfer rate? -when gravity is modified from "9.81". Do I have to use any multiplying factors to get the actual values which would have been obtained at the normal value of g=9.81? 2.How far this procedure gives correct results? Does the heat transfer coefficient and surface temperature of fins which were obtained with modified gravity and with g=9.81 are same (-provided Rayleigh number being the same in both cases)? Thanks in advance, Vidyadhar |
Alexander
Rep Power: 34 ![]() ![]() |
Why do you think, that G will influence Re and Pr directly?
Best regards |
vidyadhar
No 'g' will not influence Re, Pr |
modified gravity, natural convection |
Thermophysical properties for natural convection | Ciefdi | OpenFOAM Running, Solving & CFD | 0 | November 7, 2013 11:44 |
natural convection at high Rayleigh | mauricio | FLUENT | 2 | February 23, 2005 19:43 |
Approximate Mixing due to Natural Convection | Greg Perkins | Main CFD Forum | 0 | February 12, 2003 18:43 |
natural convection in a sealed enclosure | James | Main CFD Forum | 4 | April 2, 2001 15:48 |
Nemerical results on natural convection | Xi Man | Main CFD Forum | 0 | September 28, 1999 10:49 |
