ANSYS FLUENT workbench fan setup
Old   November 4, 2017, 18:36
Default ANSYS FLUENT workbench fan setup
Ray
mariashva is on a distinguished road
I have a question about fluent fan setup. I'm now working on a duct 40*40*100 with a pressure inlet and an exhaust fan outlet. I got a fan curve which is not linear. So I use excel to get the 5th order polynomial and put it in the fan pressure jump setup. I select turbulence model for simulation. When I run the simulation, it always shows x-momentum error, need to increase relaxation sweep. But when I changed from 0.7 to 0.5, the same error again. Then I changed the fan curve into a linear approximation, and keep the relaxation to be 0.7, it worked. So I'm not sure what was wrong when using the more accurate fan curve.
Anyone has a clue? Please help. Thanks.
mariashva is offline   Reply With Quote
Old   November 6, 2017, 13:24
Ray
Anyone can help? My understanding is that the higher order polynomial fan curve would trigger high inaccuracy when the fluid backflows along the curve. So I guess I need to restrict the flow speed within a reasonable range. But not sure how to do it in fluent.
ansys, fan, fluent
Fluent in Ansys Workbench : Change Working Directory sral FLUENT 4 March 29, 2019 11:29
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 04:34
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 05:09
Get Maxwell ansoft results in ansys workbench and find the flow velocity in Fluent, i rrahman FLUENT 0 April 16, 2016 22:11
number of iterations to converge solution in Fluent as Ansys Workbench output param nnvoro FLUENT 4 May 2, 2013 02:18
