What should be the reference area and length! |
October 29, 2017, 20:50 |
Flyer
Rep Power: 9 |
I'm studying the flow past a shrouded turbine at a constant angle of attack see attached picture. What reference area should be given to FLUENT for lift and drag coefficients? What should be the reference length for calculating Reynolds number? Thanks. |
October 30, 2017, 03:27 |
Baris PULAT
Rep Power: 10 |
Pressure coefficient, pressure drag, skin friction, viscous coefficient will all be calculated according to the exposed external surface.
That means you need the calculate the projected area of your geometry for lift and drag coefficients. Characteristic length for Reynolds is dependent on the geometry of your enclosure. You can find more on this link. https://en.wikipedia.org/wiki/Reynolds_number |
Role of Reference area for calculating drag and lift coefficients. | shashanktiwari619 | ANSYS | 0 | February 8, 2017 05:18 |
parallel code | samiam1000 | SU2 | 3 | March 25, 2013 04:55 |
Area and Length Reference Values | Eizo | FLUENT | 0 | July 6, 2012 03:42 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
