October 20, 2017, 14:50 |
Integrating data from UDF to Fluent
Rep Power: 9 |
I am currently using a UDF to simulate flow through a heat pipe. The UDF uses an initialization function to set the initial temperature, pressure, and mass flow of the heat pipe. I have been able to compile, hook the functions, and run the simulation with no error messages. However, the source terms (for momentum and mass) and my operating pressure which varies with time do not seem to be directly linked to Fluent. The resulting velocity profile is completely incorrect even though it is being formulated properly in the UDF. There is no difference in the velocity profile when I remove the source terms How can I ensure that Fluent uses the data from my UDF? Any help with this issue or even a better understanding of how data is passed from the UDF to Fluent would be appreciated. |
udf and programming |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 04:22 |
Fluent UDF for thermal NOx | larsschwarzer | Fluent UDF and Scheme Programming | 1 | July 18, 2014 09:39 |
Use of Experimental Data in fluent using UDF | anvitaa.sharma | FLUENT | 2 | February 18, 2010 11:46 |
fluent UDF external library lapack problem | Rick | FLUENT | 0 | May 7, 2008 11:16 |
UDF (write a data file) problem | lichun Dong | FLUENT | 2 | July 29, 2005 12:39 |
