Time-averaged velocity for transient flow using UDF or Data sampling
Old   October 13, 2017, 20:34
Default Time-averaged velocity for transient flow using UDF or Data sampling
7sen is on a distinguished road
Hello Everyone,
I'm conducting some research for my Master's project and I'm having some trouble figuring this out. I searched everywhere for a solution but I can't seem to find one.
I've only seen one reply but I can't access the UDF they provided (http://www.eureka.im/1104.html)
I'd really appreciate it if someone can help me. An example is this:
I iterated my case till timestep no. 200, saving files after every 10 timesteps. Now I want to see the average velocity for timesteps 50 to 120.
I tried looking at Data sampling, but I couldn't find a place where I can choose from timesteps 50 to 120; or any range of timesteps that is.
I would really appreciate any help.
Best Wishes,
HZ
7sen is offline   Reply With Quote
Old   October 18, 2017, 12:11
Martin
2phase is on a distinguished road
Hi HZ,
best way is to define your own monitor points and report files.
On the left hand side in "monitors" you can define your own statements/parameters/monitor points for surfaces or volumes like "mass weighted average of velocity @ inlet" similar things.
Then you can plot them like the residuals or check to write them to a file in your solution directory... if you have several variables you can create a report file and get them all into one file with values for every time step / iteration and then process them in Matlab or whatever.
Of course you need to define this before running the simulation, I do not know if there is an option for getting this data after a calculation similar to what you just tried.
Good luck trying.
Martin
2phase is offline   Reply With Quote
average, fluent, time, transient, velocity
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
