Rayleigh number Custom field function
Old   October 13, 2017, 01:26
Default Rayleigh number Custom field function
Praphul T
praphul is on a distinguished road
Hi ,
I would like to plot a custom field function of Rayleigh number with time in Fluent. ( I am simulating a natural convection problem in a 3D rectangular enclosure ). The formula for Rayleigh number is Ra = \frac{g \beta \Delta T L^{3}}{\nu \alpha} . I would like to get the values of these fluid properties from the simulation.
The problem is i am unable to find these properties and constants g, \beta ,\Delta T , L , \nu , \alpha inside custom field function in fluent while defining the cff. Is there a solution to this problem ? Can anyone guide me on how to implement it ?
Thanks in advance.
praphul is offline   Reply With Quote
Old   November 4, 2017, 10:26
Praphul T
It will be certainly helpful if some can help me on this issue. It might seem trivial to some of you but can help a lot in getting ahead in the learning curve.
Old   November 13, 2017, 02:48
Vignesh Lakshmanan
ViLaks is on a distinguished road
Originally Posted by praphul View Post
Hi ,
Thanks in advance.
You know g is 9.81; Your beta is thermal expansion coefficient, which is 1/T (1/fluid temperature). L is characteristic length which is Volume of the body/Surface area of the body; Dynamic viscosity (Nu) , Diffusivity (alpha) can be easily found onlne at the corresponding fluid temperature
ViLaks is offline   Reply With Quote
custom field function., fluent, natural convection, rayleigh number, udf
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 13:55
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 10:01
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 01:35
