saving plane surfaces created in postprocessing
Old   October 11, 2017, 04:03
Question saving plane surfaces created in postprocessing
Gerrit B
gerritb is on a distinguished road
Hello everyone!
To evaluate the temperature distribution in an air volume after solving the simulation, I created several 'plane surfaces' (using these GUI commands: postprocessing>surface>create>plane...).
After saving my project and reopening, these plane surfaces don't exist anymore. Is there a special way to save these? I don't want to create them again every time I reopen my project.
Thanks!
P.S.: I searched the FLUENT forum a post regarding this problem, but was not able to find anything related. Maybe the solution is too obvious...?
gerritb is offline   Reply With Quote
Old   October 11, 2017, 04:11
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
If you saved case file, there should be no problems, all settings and data inside is saved. Try to create any plane and save case file, then reopen -> check created plane
Best regards
AlexanderZ is offline   Reply With Quote
Old   October 11, 2017, 04:29
Gerrit B
Ok, it works as you said. Maybe I messed something up when I tried it earlier...
Thank you!
create surface, plane, save, saving, surfaces
Problem with Sampling plane Chander CFX 10 February 20, 2012 17:57
postprocessing - surface - plane Brujo FLUENT 2 March 1, 2008 11:36
ICEM and symmetry plane Roland CFX 3 September 13, 2006 09:38
UDF with user created surfaces Henry Lee FLUENT 2 March 23, 2006 04:24
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
