transient heat in jet impingement on a flat plate
Old   October 8, 2017, 10:04
Default transient heat in jet impingement on a flat plate
waqar hazoor
waqarha2003 is on a distinguished road
can anyone help me in simulation of circular air jet impingement on a heated flat plate.
i want to find the influence of diameter of jet on heat removing form plate. or simply cooling of plate with different jet diameters.
i am using ANSYS fluent 16 and want to simulate this work.
thanks in advance.
waqarha2003 is offline   Reply With Quote
Old   October 8, 2017, 15:29
Default reply
waqar hazoor
hi,
can anybody reply . i need some help if some one did this type of work. urgent please
Old   October 8, 2017, 20:01
Lane Carasik
lcarasik is on a distinguished road
Flow impingement on a plate by different jets is a common research topic. If you're looking for help to set up a simulation, I recommend looking at the tutorials for fluent.
lcarasik is offline   Reply With Quote
Old   October 16, 2017, 10:14
ritwik_101 is on a distinguished road
I am working on axisymmetric jet impingement on a flat plate and even I had the same doubt of how to set up the simulation in ansys fluent as I dont know which turbulent model to select, how to calculate appropriate turbulent characteristics and the meshing of control volume of the same. Help needed here.
ritwik_101 is offline   Reply With Quote
Old   October 17, 2017, 13:24
waqar hazoor
i go through lot of tutorials but still can not get what should i do how to design model for jet impingement. plz help
Old   October 18, 2017, 23:46
Lane Carasik
Hi, what are you trying to do so far? What is your geometry set up? What boundary conditions have you tried?
Also, have you looked at the literature? Jet impingement is a very popular CFD case.
Old   October 19, 2017, 14:09
waqar hazoor
actually my objective is to find the cooling time of plat under different parameters like diameter of circular jet, velocity and spacing between jet and plate. most of the researchers have done the cases on heat transfer from plate in the form of nusstle number. but i put it simple to just find the cooling time. for that i set the boundary conditions as initial temperature of plate would be 100C and jet temperature will be 25C and simulate it with different diameters and velocities etc to find which case is optimum. can u please suggest me from where should i start. thanks
Old   October 19, 2017, 14:15
Shrirang
shrirang is on a distinguished road
You can consider average Nusselt number value as an indication of heat transfer to compare between your cases of study.
shrirang is offline   Reply With Quote
Old   October 20, 2017, 02:58
Lane Carasik
Yes, you can use a similar geometry and mostly similar boundary and initial condition set up. Also, shrirang has a good point in that you can likely approximate the cooling time though the nusselt number.
Old   October 22, 2017, 13:27
Saurabhyadav is on a distinguished road
Can anyone suggest how to select grid and hoe to validate my result for that
Saurabhyadav is offline   Reply With Quote
Old   February 1, 2018, 14:50
waqar hazoor
dear can you kindly guide me how to calculate the Nusstle number at a stagnation point in transition case, i want to plot Nusstle number vs Re to validate my case with others
Tutorial 3. Flow and Heat Transfer over a Flat Plate cheredha FLUENT 4 October 16, 2021 03:19
How to model a co flowing mist jet of air and water impinging on a flat plate with Eu vikash kumar singh chauha Fluent Multiphase 0 August 28, 2017 02:45
Jet Impingement Heat Transfer robin kumar thapa Main CFD Forum 0 March 15, 2017 09:52
Flat Plate Boundary Layer Height kennedy1992 Fidelity CFD 7 February 24, 2016 05:45
Best Turbulence Model for Heat Transfer in Jet Impingement ara STAR-CCM+ 5 July 25, 2014 12:45
