Bioheat brain UDF
Old   October 6, 2017, 21:40
Default Bioheat brain UDF
sau
sau is on a distinguished road
Hi CFD Online,
This is my first post on the forum. Please excuse any mistakes I make and I appreciate any help you may offer.
I am currently working on modelling the heating of brain tissue and have found in literature that Fluent UDFs can be used to introduce the metabolic and perfusion in the bioheat equation as source terms.
The bioheat equation is referenced here.
Based on this, I have written the UDF (please see attached) for the metabolic and perfusion terms. I then interpreted and applied the UDF to a sphere with brain material properties. The boundary condition is set to a constant 310.65 K.
However, the solution is failing to converge and I am wondering if my approach with the UDF is correct?
Please let me know if anything else I can add to help and thanks in advance.
File Type: c brain_bioheat.c (866 Bytes, 15 views)
sau is offline   Reply With Quote
Old   October 9, 2017, 22:12
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
What kind of error did you get?
UDF looks correct
Best regards
AlexanderZ is offline   Reply With Quote
bioheat, define_source, fluent, udf
UDF using c_face_loop(c,t,i) frederic FLUENT 3 January 17, 2017 00:17
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
Parallelize UDF? Which kind of UDF? Lilly FLUENT 5 March 25, 2014 03:05
Help! Delete the UDM codes in the UDF Messi Fluent UDF and Scheme Programming 2 January 28, 2014 10:01
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
