October 2, 2017, 14:01 |
Particle displacement 6DOF
David
Rep Power: 9 |
Hello everyone.
Im trying to move a 4 mm particle on a normal flow of a pipe 10 mm inlet and 200 mm lenght with the 6DOF implementation, but every time i start the simulation i get a negative volumen cell and my particle move far away from my mesh. i want to make something like this videos: https://www.youtube.com/watch?v=_VLUbhNz6Dk https://www.youtube.com/watch?v=lVmNGA3w-gs https://www.youtube.com/watch?v=Jfqpv3jQH_A my set up: transient analysis Laminar flow material water velocity-inlet: 0.005 m/s Pressure-outlet: 0 Dynamic mesh: smoothing (spring factor 0.5)+ remeshing (default parameters) + 6DOF (gravity 0) Solution Methods: p-v : simple pressure: second order momentom: second order This its my UDF #include "udf.h" DEFINE_SDOF_PROPERTIES(falling_box, prop, dt, time, dtime) { prop[SDOF_MASS] = 7e-4; prop[SDOF_IZZ] = 1.0993061e-6; prop[SDOF_IXX] = 1.0993061e-6; prop[SDOF_IYY] = 1.0993061e-6; prop[SDOF_ZERO_ROT_Z] = TRUE; prop[SDOF_ZERO_ROT_X] = TRUE; prop[SDOF_ZERO_ROT_Y] = TRUE; printf ("\n2d_test_box: Updated 6DOF properties"); } |
October 3, 2017, 10:13 |
David
Rep Power: 9 |
Finnaly i do it, i was setting wrong my mass for my 2D particle. The mass need to be calculate with 1m depth. i will try know to run the 3D case and i will update if i need help or i got it.
Particle tracking error | alchem | OpenFOAM Bugs | 5 | May 6, 2017 17:30 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 11:58 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 10:53 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 02:30 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 02:29 |
