September 27, 2017, 11:44 |
Mixing Plane Issue
Chris
I'm using a mixing plane to model a stator-rotor fluid interaction. I followed other examples and feel confident that I have the correct boundary conditions. My flow solution even looks reasonable, however, after a few hundred iterations none of the properties are circumferentially averaged at the mixing plane interface. From what i understand the properties have to be averaged at every iteration and passes to the stator exit or rotor inlet before each domain can be iterated again. Has anyone seen this behavior before? |
mixing plane causes fatal error | amin.z | FLUENT | 1 | October 27, 2023 08:14 |
problems with mixing plane | dowlee | OpenFOAM Running, Solving & CFD | 6 | September 21, 2016 01:14 |
Mixing plane for centrifugal compressor | Mitpostdoc | FLUENT | 0 | March 24, 2011 18:27 |
Meshing a Mixing Plane using ICEM | Will Anderson | FLUENT | 0 | November 6, 2010 18:08 |
mixing plane in CFX5.5.1 | joseph | CFX | 1 | April 17, 2002 19:09 |
