a possible substitution of heat exchanger module in fluent?! |
September 25, 2017, 16:49 |
how could i validate a double pipe heat exchanger?
Sadegh
Rep Power: 11 |
Hi every one
I want to simulate a double pipe heat exchanger in Fluent and in order to validate it, instead of using heat exchanger module I want to use a single pipe (as inner pipe) and a heat flux boundary conditions at its surrounding. The quantity of this flux will be calculated by simulating a similar heat exchanger in Aspen HYSYS. Now here is the question: is this reliable? I mean I can find flux quantity but I guess we can’t say heat distribution on this single pipe wall will be same as my mentioned method in Fluent. As an example consider a counter-current and a co-current flow arrangement. It’s obvious for a same quantity of heat flux we will have different dimension size of heat exchanger, now if I use a same reported dimensions and quantity by Aspen (whether co or counter-current) could I use the above suggested method to simulate a double pipe heat exchanger? Thanks for your consideration Last edited by Sadegh.A; October 3, 2017 at 14:13. |
double pipe, heat flux, hysys, validation |
Heat transfer analysis of heat exchanger with complicated shape and irregular fins | Mahesh Patil | CFX | 1 | September 29, 2016 13:07 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Ansys Fluent analysis of heat exchanger | MStudent | FLUENT | 2 | April 20, 2015 09:40 |
Heat trasfer coefficient in a pipe - Fluent | elios | FLUENT | 1 | February 6, 2015 15:18 |
Simulation flow loop of Heat exchanger | lalolala | FLUENT | 1 | November 22, 2012 00:53 |
