How let finished simulation to run more steps? |
September 25, 2017, 10:39 |
burke
Rep Power: 9 |
My simulation of a steady heat transfer in Fluent reaches convergence in 120 iterations. How to let the case to run another 80 iterations? I know I can run a new case and let it run 200. I am wondering how to use the result of 120 iterations to run. Thanks!
September 25, 2017, 10:49 |
Rep Power: 14 |
Disable automatic convergence detections. Solution->Monitors->Residual->Convergence Criterion->"none"
September 27, 2017, 10:06 |
burke
Rep Power: 9 |
I want to know how to use the result of 120 iterations to run.
September 27, 2017, 11:07 |
Rep Power: 14 |
September 27, 2017, 12:38 |
burke
Rep Power: 9 |
How to load the data with 120 iterations? The problem is two steady flow heat transfer. I want to compare 120 with 200 steps to make sure there is no change.
help to run CFX simulation via HPC, please | happy | CFX | 19 | February 28, 2016 18:18 |
Simulation Problem Where Suddenly Finished With No Result Produced | PeiSan | Fidelity CFD | 4 | August 21, 2014 08:06 |
unable to run the caradonna blade simulation | deeps | SU2 | 5 | June 24, 2014 21:53 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 08:36 |
Procedure to run unsteady simulation? | STN | Main CFD Forum | 2 | February 16, 2002 05:37 |
