September 24, 2017, 10:56 |
simulation of coronaries bypass
amirreza
Rep Power: 9 |
hi. I want to simulate coronaries bypass. My geometry contains right coronaries & left coronaries and aorta. for boundary conditions, I have inlet & outlet flow of aorta, and as we know the pressure in all coronaries is the same as the aorta. can I set for my all outlets pressure outlet which is aorta pressure? I have read in some papers, they've used outflow conditions for outlet boundaries which they calculate flow rate weighting by Murray's law.does anybody know about Murray's law here? or how we can calculate flow rate weighting for each artery? for some arteries, I have outlet flow. how can I use outlet flow in fluent? should I just negative the flow for the outlet?
September 26, 2017, 19:06 |
Lucky
Rep Power: 66 |
Be careful because it is very easy to measure everything experimentally and have too much information as input for CFD.
If you know your outlet flow, chances are you should be using a pressure outlet with targeted mass flow rate. If you know the flow weights, use the flow-split BC. If you want to specify the outlet pressures do so, but here you will not be able to control the flow-rate through each. |
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 03:28 |
Simulation FPEs - turbulence for transient and steady-state? | DaveR | OpenFOAM Running, Solving & CFD | 5 | March 5, 2017 16:06 |
Waterbell Simulation | o.b.m | Fluent Multiphase | 1 | November 5, 2015 06:55 |
setting up a simulation with multiple interactions | phandy | OpenFOAM Running, Solving & CFD | 1 | October 6, 2014 04:16 |
Continuous vs interrupted simulation | sega | OpenFOAM Running, Solving & CFD | 4 | November 3, 2008 15:29 |
