September 22, 2017, 23:34 |
Gradient Adaptation - (Segmentation fault).
David
Rep Power: 9 |
Hello everyone.
I get the following error when im trying to do an adaptation for a mesh that i alredy calculate the solution. (open a file case/data after do simulation) Error: received a fatal signal (Segmentation fault). Error: received a fatal signal (Segmentation fault). Error Object: #f When i adapt immediately after the simulation end i can adapt but after open the file is when i get the error message. I read that can be problem for the UDF so also i add my UDF. Thx |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 15:42 |
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 06:35 |
Segmentation fault in SU2 V5.0 | ygd | SU2 | 2 | March 1, 2017 05:38 |
Segmentation fault when running in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 8, 2015 09:12 |
segmentation fault when installing OF-2.1.1 on a cluster | Rebecca513 | OpenFOAM Installation | 9 | July 31, 2012 16:06 |
