September 22, 2017, 08:44 |
C_VOF error "store_vof_norm" in fluent
Rep Power: 16 |
Hello All:
I have written an UDF to calculate mass transfer rate in multi-phase flows using Eulerian model. I am calculating mass transfer rate from vapor to liquid for which I need volume fraction of both the phases at each cell locations. I am facing problem while interpreting/reading cell variable C_VOF in fluent. The error massage I receive is as follows: "line 91: label "store_vof_norm" not found (pc=185)." Please someone help me how to access the volume fraction of both the phases in UDF. Thank you Shoonya |
September 23, 2017, 04:18 |
Now C_VOF working
Rep Power: 16 |
Hello:
Just want to inform that C_VOF is working now and it no longer give error "store_vof_norm". I ran the UDF code in Linux version of fluent and it did not give any error. The UDF is interpreted without error. It may be some .net version problem in windows but I cant confirm this reason. The thread may be close now Thank you With Regards |
multiphase, store_vof_norm, udf, vof |
CFX vs. FLUENT | turbo | CFX | 4 | April 13, 2021 08:08 |
How to solve UDF compilation problems in Fluent. | pakk | Fluent UDF and Scheme Programming | 16 | September 10, 2018 02:48 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 06:22 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 16:48 |
