Sharp corner_inflation option
Old   September 20, 2017, 14:56
Exclamation Sharp corner_inflation option
Tatiana Flechas
tatiana33 is on a distinguished road
Hello!
I'm trying to mesh a pipeline (represented by an axisymmetric rectangle), having smaller cell size in the upper side and on the right side of the rectangle. I have been using virtual topology in order to divide the mesh in 4 sections (see picture attached).
Section 1: face meshing function.
Section 2: inflation function 1
Section 3: inflation function 2
Section 4: combination of inflation functions 1 and 2.
The problem is on Section 4, I would like to combine the 2 inflation options in order to have smaller cell size in the corner but I'm not getting quadrilateral cells. I tried to use pinch tools with no success.
Could you please help me with some ideas about how to improve the right corner of my mesh?
tatiana33 is offline   Reply With Quote
Old   September 26, 2017, 10:03
Post
Ovid
Fole is on a distinguished road
I do not know either how to do it in ANSYS Meshing, but in ICEM CFD it would be straightforward.
Fole is offline   Reply With Quote
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 03:54
Compression stoke is giving higher pressure than calculated nickjuana CFX 62 May 19, 2015 14:32
particle tracking sakurabogoda CFX 7 December 5, 2013 00:12
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
