September 20, 2017, 07:55 |
Flow over multiple bluff bodies
Thamilmani M
Rep Power: 9 |
I have to do a flow over multiple square cylinders in tandem arrangement at Re 100 and get Cd Cl plots. But I find my results are wrong. I am getting zero Cl. Can anyone please tell me if the solver conditions I have given are right or not? 1. Models - Transient - 2D Laminar case 2. Material - air - density - 1 kgm-3 and viscosity 0.01 kgm-1s-2 3. Inlet - velocity inlet - u = 1ms-1 4. Outlet - pressure-outlet - Gauge pressure 0 5. Top and Bottom boundaries - Stationary Wall - Shear stress - 0 6. Cylinders of 1m side, 1.2 m apart and no-slip Boundary Condition. 7. upstream is at 7m from the cylinder and 32 m is downstream to the cylinder. I am getting Cl plots zero, PISO - Second order and vortices are standing at the rear end. |
2dproblem, bluffbody, multiplecylinders, squarecylinder |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Flow between two bodies | guihds | Main CFD Forum | 0 | April 2, 2014 09:13 |
Asymmetric solution for bluff bodies symmetric tandem | bud_el_lodituma | Main CFD Forum | 7 | March 18, 2014 15:07 |
[DesignModeler] Subtracting multiple bodies | Rhyno466 | ANSYS Meshing & Geometry | 3 | March 14, 2012 01:10 |
Kármán vortex street in cavitating flow behind bodies in the cavitation tunnel | L. Könözsy | Main CFD Forum | 0 | April 17, 2000 13:16 |
