September 20, 2017, 07:16 |
FLUENT 6DOF dynamic mesh error pressure
胡杭辉
I would like to use Fluent to simulate the movement of a floating body. I am currently experimenting with dynamic mesh and a "simple" model (2D): I use a rigid rectangular body of 1.54*0.08m in a box of 7.7*0.34m. For the boundary conditions I use the same parameters as Fluent tutorial "Solving a 2D Box Falling into Water". The only difference are the dimensions and the fact that my body is already immerse (by 0.04m) in the water (water height is 0.18m). I meshed the whole domain with trias and used the following UDF to parameter the 6dof model: #include "udf.h" DEFINE_SDOF_PROPERTIES(sdof_properties, prop, dt, time, dtime) { prop[SDOF_MASS] = 61.49; prop[SDOF_IXX] = 129.6296; prop[SDOF_IYY] = 111.1111; prop[SDOF_IZZ] = 129.6296; prop[SDOF_ZERO_TRANS_X] = TRUE; prop[SDOF_ZERO_ROT_Z] = TRUE; printf ("\n updated 6DOF properties"); } Before using dynamic mesh I started the calculation with the body fixed in order to get hydrostatic pressure. Then I allowed the body to move but after roughly 5 time steps, I get the error: "Warning: non-positive volumes exist. Error: Update-Dynamic-Mesh failed. Negative cell volume detected. Error Object: #f" And when i display the mesh, I can see that the body has moved out of the box... If I stop the calculation after 2 or 3 time steps and display the pressure, I can see that I get huge values. If I calculate the lift force on the body, the force is also bigger than what it should be. If i look at the lift force history, when the body is fixed, I get 610.13984 N but after I allow the body to move it is oscillating with amplitude such as -2468606 N, 1.2394356e+08 N, ... until I get the error message. From what could this instability come from? I really don't understand why it does something like that... Could someone help me solve this problem? Thanks |
Ship resistance shows wiggles when using Overset mesh and dynamic mesh in Fluent | Qingsong | FLUENT | 2 | March 21, 2022 15:08 |
Problem concerning FLUENT dynamic mesh | fabian.g | FLUENT | 0 | August 28, 2017 11:56 |
dynamic mesh tutorial files for fluent | hesham | ANSYS | 0 | February 2, 2016 19:51 |
dynamic mesh tutorial for fluent | hesham | FLUENT | 0 | February 2, 2016 10:43 |
FSI. Fluent divergence issue due to Dynamic Mesh | Svensen | ANSYS | 2 | January 28, 2016 01:41 |
