Bilal Waseem
Rep Power: 12 ![]() |
I am trying to verify the results of a research paper regarding simulation of toxic gas release. I am using Ansys Fluent Solver. Basically, first I ran a steady state analysis with wind blowing in a certain direction and certain velocity. Then I added a leakage source with mass flow boundary condition and ran a transient analysis for a gas release for 3 minutes duration (keeping the steady state results as initial condition). The result that I am looking for is mass fraction of gas at different locations in solution domain. At a height of 1.5 m from ground, the research paper plots its results for a fraction of 2.0e-5. My contour completely matches with the paper, except near the release point. In the paper, gas dispersion starts at the release point whereas in my case, gas releases disperses ahead of the release point in the forward direction with no dispersion along the plane of leakage source. So my results say that gas is not dispersing in the backward direction whereas in the paper, it disperses even behind the leakage source. In the attachment, the contours on the left are from the paper. I am simulation the case for wind speed of 0.75 m/s (contour No. 1). My results for the same wind speed are on the right. What could I be doing wrong? I have modeled everything as recorded in the paper. Please help. Last edited by billy7590; September 13, 2017 at 15:57. Reason: Forgot to add an attachment |
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
I think that no one can say what is the reason of the difference without the details of the two simulations... Is the grid the same? Is the setting of the BC.s the same? Is the setting of the transient integration the same? Is the formulation the same?
I can only suggest to do also the comparison between the velocity fields |
#3 | |
Bilal Waseem
The type and accuracy order of the discretization can also be a relevant difference.
Bilal Waseem
The paper that I am verifying does not give any information regarding discretization. Could you please shed some light on what type of discretization and accuracy selections will give better results ...??
dispersion, fluent, gas |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
CFD simulation of gas cicrcuit breaker in fluent with dynamic meshing. | Mahesh7238 | FLUENT | 1 | April 5, 2021 00:21 |
Ideal gas v.s. Real gas for wing simulation | Anna Tian | Main CFD Forum | 1 | December 16, 2013 11:39 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Diesel combustion simulation ( Heat release rate) | venkatesh | Siemens | 2 | April 29, 2009 07:38 |
