Importing Chemkin Reaction into Fluent
Old   September 8, 2017, 05:46
Default Importing Chemkin Reaction into Fluent
sunil kumar
skumar112 is on a distinguished road
Hi
I wanted to know if anyone had any tutorials (or if someone could explain) of how to import a reaction reduction from CHEMKIN into fluent. I am new to Chemkin, So I believe I have created a reaction reduction mechanism correctly using there tutorial guides. However, there is no information on either fluent or chemkin as to how to get the file into the correct format or which file needs to be imported (as chemkin dumps 100's of files into the working directory all with very similar names and types just differing by iterations of runs). I would really appreciate the help
Thankyou in advance
skumar112 is offline   Reply With Quote
Old   January 4, 2018, 11:53
adam
poutivar is on a distinguished road
Hi. I hope you found an answer to you query.
If not, try this: File-->Import-->Chemkin mechanism, there you can load your Chemkin files (reaction mechanism file and thermodynamic properties). They usually are in DAT format.
Next you can use it in your combustion analysis.
Hope this helps.
poutivar is offline   Reply With Quote
Old   March 22, 2018, 22:56
Weiqiang Liu
Weiqiang Liu is on a distinguished road
hi,
have you figured out how to import chemkin format into fluent. I've been doing methane combustion simulation with fluent . The gas phase and surface mechanism are imported into Fluent. however I got a error 'received a fatal signal (segmentation fault)'
have you ever met this error?
Weiqiang Liu is offline   Reply With Quote
chemkin, combusting, combustion, fluent, reaction mechanism
Importing hypermesh file in FLUENT Tanuj FLUENT 1 August 1, 2017 00:50
problem while importing file from chemkin to ansys in fluent srinathsol CFD Freelancers 0 June 12, 2017 08:33
chemkin for fluent tutorial hamdireza FLUENT 1 November 20, 2015 07:56
chemkin fluent hamdireza FLUENT 5 July 27, 2015 14:54
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 01:07
