Fluent (High Lift Prediction workshop) error
Old   September 7, 2017, 21:46
Default Fluent (High Lift Prediction workshop) error
Jose
jd.ramirez14 is on a distinguished road
Hello everyone
I'm currently doing a simulation (High Lift Prediction Workshop) of an airplane in landing configuration (flaps & slats). I'm using a semi-spheric mesh surrounding the plane as a pressure far-field (boundary condition)
However, upon simulating I always get the same error code:
Error: Cortex received a fatal signal (SEGMENTATION VIOLATION).
Error Object: ()
Error: cx-enable-item: wta[1](Widget)
Error Object: #f
I'm using Spallart-Allmaras model with curvature correction. I've triple-checked everything in the simulation and haven't been able to find any errors.
Does anyone know how to fix it?
Many thanks
jd.ramirez14 is offline   Reply With Quote
Pressure outlet boundary condition rolando OpenFOAM Running, Solving & CFD 62 September 18, 2017 07:45
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
