Fluid Coupling (Hydraudynamic Coupling)
Old   September 7, 2017, 12:25
Question Fluid Coupling (Hydrodynamic Coupling)
Darma Yuda
sdarmayuda is on a distinguished road
I'm Darma. I'm new to this forum and also to this Program. I am still learning ANSYS Fluent by myself with help from Youtube. I'm currently working on a project about hydrodynamic fluid coupling. I have already made the boolean from my model. I want to give a torque as my input, but I only saw a constant rotational velocity as my input in Mesh Motion. Someone told me to try Frame Motion or UDF. I have really no clue about those two. Can you guys explain to me about those and what is the different with Frame Motion and Mesh Motion? Or Do you guys have some link or website, where I could get the tutorial about that?
And is it possible to have the transmitted Torque as the result from this simulation, because until now, I have seen only pressure, density, and velocity as my option for the result.
Thanks before.
Best Regards,
Darma
sdarmayuda is offline   Reply With Quote
Old   September 20, 2017, 07:16
Darma Yuda
So has anyone here made a model and simulation of fluid coupling with Fluent? I'm trying to use constant rotational velocity and I figured that I also have to input the rotational velocity of the turbine blade. In Fluent the fluid flow, which is caused by the rotation of the pump blade, apparently can't make the turbine blade rotate.
So my question is: Has anyone here had a similar experience? And how did you guys/ make this simulation works?
Any help would be much appreciated!
Darma
fluid coupling, frame motion, torque, udf
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 06:07
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 05:59
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
FSI: Pressure and Normal Force don't match with expected values Geraud CFX 6 August 21, 2012 16:34
