Scheme (or UDF) load Parameter value
Old   September 4, 2017, 05:25
Default Scheme (or UDF) load Parameter value
HHOS is on a distinguished road
I need to modify the rotational speed of a MRF zone in order to reach a certain value of pressure jump.
I plan to do it reading a Scheme file (.scm) every X iterations. The only problem I have to do so is that I don't know how to read the "rotation" value of the MRF zone in order to decide which the new value will be.
I have thought that it might be easier to define it as a parameter (Menu Define -> Parameters) to read from it and write into it.
However, I have no clue about how to access it. In the command line interface I checked the option (/define/parameters/input-parameters/advance/use-in) and I guess it has to be related to it. Still, I am not sure about how the referencing to the parameter must be done.
I hope somebody can give me a hand with the topic.
Thanks in advance. Regards.
HHOS is offline   Reply With Quote
fluent, parameter variation, scheme
Changing Pressure-inlet to Wall for Inlet valve (from UDF and Scheme) esco_rep Fluent UDF and Scheme Programming 2 December 7, 2024 06:35
how to load UDF in parallel at linux platform maye761 Fluent UDF and Scheme Programming 9 April 13, 2018 04:30
Force can not converge colopolo CFX 13 October 4, 2011 23:03
How to implement a numerical scheme by using UDF? Furui Xiong FLUENT 0 July 29, 2010 02:30
Parameter for the cubic upwind scheme in OpenFOAM JinBiao OpenFOAM 1 May 23, 2010 04:51
