50 Species Limit-Fluent IC Engine Analysis
Old   September 1, 2017, 14:14
Default 50 Species Limit-Fluent IC Engine Analysis
CR
Cramsay is on a distinguished road
So I know that the more species involved in the chemical mechanism, the higher the computational expense. But what are the reasons for the 50 species hard limit, and are there any workarounds?
Like say for example I wanted to use a 51 species mechanism, would there be a way to do so.
I'm currently using Fluent 17.1 and using the Diesel Unsteady Flamelet Model to analyse compression and power strokes in a CI engine (if this has any relevance).
Any help/insight would be appreciated.
Cramsay is offline   Reply With Quote
chemical, diesel, limit, mechanism, species
fluent subsonic wing analysis problem fatihcoban FLUENT 0 August 3, 2016 10:41
How to carry out 3D shell and Tube Heat Exchanger analysis in fluent medogalal FLUENT 3 December 30, 2015 05:28
How do you do a fluent CFD analysis for a boat? UHMStudent FLUENT 2 July 24, 2011 13:45
Boundary Conditions for aircraft engine in Fluent 6.3 Tareen FLUENT 0 July 20, 2011 01:05
2D Fluent CFD Analysis lamboram FLUENT 0 July 12, 2011 14:02
