August 31, 2017, 09:37 |
Fixed velocity profile: exploding solution
Cees Haringa
Hi all,
I have to model a tank with a recirculation (cooling) loop. Since there are no in/outlets, I attempt to force the flow through the loop by setting a small fixed-velocity flow profile in a section of the loop where we know there is unidirectional, turbulent and developed flow. I do so via a UDF which supplies the typical (1-r/R)^(1/7) profile. However, the solution explodes as soon as I start solving. At first I tried with a fixed velocity of 1 m/s, I though in that case the exploding solution may be due to forcing a non-zero velocity at the wall. However, with the UDF this should not be an issue - and the solution still explodes even if I force the outer layer of cells to have 0 velocity. Even when I set the velocity in all grid cells of the fixed-velocity section to 0, the mean velocity in the domain soon reaches c^2 EDIT: setting no-shear b.c. to the relevant cell zone walls doesn't help either, neither does using the transient solver instead of steady-state Any ideas on why this may be? |
August 31, 2017, 10:36 |
Cees Haringa
Solution appearantly was to not just fix x-velocity to desired flowrate, but also y- and z- velocity to 0
velocity profile in a simple cylindrical flow tube | Diger | FLUENT | 0 | December 29, 2016 21:05 |
3D Velocity profile for turbulent flow | Kirill | Fluent UDF and Scheme Programming | 3 | July 17, 2014 08:42 |
[swak4Foam] groovyBC error: velocity profile (2D) >> what's wrong? | vitorspadeto | OpenFOAM Community Contributions | 4 | June 19, 2014 15:31 |
deviated velocity profile | rayan24 | Main CFD Forum | 0 | July 3, 2013 16:34 |
particle velocity and velocity profile | HGG | FLUENT | 2 | June 10, 2001 16:32 |
