How to make the convergence of fluid machinery better
Old   August 31, 2017, 09:30
Post How to make the convergence of fluid machinery better
max wang
max610105 is on a distinguished road
hi all
I use fluent to to simulate a centrifugal fan.
My settings are as follows
Solver type:Pressure based
Velocity Formulation:Absolute
Time:steady
Model:K-e (RNG)<i try k-omega too
solution methods:simple
when fan speed is 1000 RPM , Volume flow rate is more steady than 10000 RPM
I try different turbulence model and more dense mesh
it didn't work
could someone can tell me how to solve this kind of problem thanks a lot
max610105 is offline   Reply With Quote
Old   August 31, 2017, 09:37
Cees Haringa
CeesH is on a distinguished road
How are you modeling the fan itself? Did you try a transient rather than steady state simulation? If there are inherent periodic effects, forcing into steady state may give issues. (and why RNG k-e? in my experience, it performs really poor for stirred vessels, so I expect little better for fans)
CeesH is offline   Reply With Quote
Old   August 31, 2017, 22:35
max wang
sorry i don't know what you mean in first question(I use pro/e to model the fan)
because transient need more time , thanks for the information i will try transient state simulation again
in you experience , which model is better?
fan
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 07:08
Fluid Flow over a bus -- Convergence Problem Roberto J. STAR-CCM+ 2 May 12, 2016 14:05
how to make analysis from the result in fluid flow (CFX) ansys workbench 14 wan11 CFX 3 December 18, 2014 20:25
How to choose the mean diameter value for dispersed fluid? creddy_trddc CFX 1 October 30, 2011 05:30
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
