Problem with Finite Rate in Combustion Modeling
Old   August 30, 2017, 06:43
Default Problem with Finite Rate in Combustion Modeling
mengke zhan
mengke is on a distinguished road
Hi guys!
I am having some issues regarding using the finite rate method in combustion modeling.
I am modeling a simple laminar premixed combustion case between propane and air (single step chemistry). I have the inlet boundary condition with 0.2m/s and stoichiometric mixture of propane and air. However, after patching the convergent cold non-reacting flow at 3000k near the inlet and run it under the finite-rate model. The temperature returns back to 300k soon after. I have also tried patching the reactants, too and it does not work, either.
I also tried a turbulent case with velocity 10m/s. The EDM method works while the finite rate method still gives extinguishing results.
I am wondering what might be the problem here.
Thanks!!!
mengke is offline   Reply With Quote
Old   March 8, 2021, 15:09
el tneen
Ahmed13 is on a distinguished road
hi Mengke
i am having the same problem ,did you have solution for it ?,thanks in advance
Ahmed13 is offline   Reply With Quote
combustion, edm, finite rate, laminar
Massflow rate problem for an incompressible flow clecle69 STAR-CCM+ 12 March 1, 2017 15:29
Problem: Convergence in unsteady EBU combustion model Defend STAR-CCM+ 7 April 22, 2014 15:48
Combustion Modeling with COMSOL davidst COMSOL 0 January 11, 2013 13:39
Combustion problem in STAR CD... help me, please! mrkokoko STAR-CD 1 September 14, 2009 18:00
Diesel combustion simulation ( Heat release rate) venkatesh Siemens 2 April 29, 2009 08:38
