Moisture diffusion by species transport between air and porous desiccants |
August 29, 2017, 02:50 |
Moisture diffusion by species transport In porous desiccants
SHAMIM JUBAIR
Rep Power: 9 |
Hello Everyone, I am trying to solve water vapor mass fraction using non reacting species transport. I have prepared a UDF too to capture adsorption of water vapor into porous media. When I use a single domain e.g. only a rectangular fluid domain and define porous media with in it, my model works fine. It means, my UDF has no problem. But when I create two domains, one is air channel and another is porous media (as shown in Simulation_Details) and there is an interface between air and porous media which is defined as wall, my model does not work (I created mesh interface properly, and coupled those two zones, so I believe mesh interface is not a reason). I set constant mass fraction as boundary condition at the wall between air and porous media. I am not sure how to set inputs for species transport model at interface between two different zones. I have attached herewith a file describing the details of my modeling procedure and model tree. I have been stuck for a month and could not move forward. If someone knows, how to solve this issue please please help me. I am using volume weighted mixing law for Density and Mass weighted mixing law for viscosity and thermal conductivity in Species Transport Model as shown in Pic. Currently I am using 4 UDS. UDS-0 calculates Meq, UDS-1 calculates M, UDS-2 calculates dM/dt and UDS-3 calculates Energy Source term as described in the governing equations in attached PDF File. So, I am not sure how to specify BC at interface walls and Inlet for above UDS. Looks like I can specify only a constant value as shown in pic attached but I don't know how to calculate that constant value.
Last edited by jas123; August 30, 2017 at 04:45. Reason: To draw attention of more readers |
April 14, 2019, 13:51 |
#2 | |
Akash Siddique
Rep Power: 8 |
I'm working on the same problem ... did you solved it.. if you have please guide me and provide udf if possible best regards needy |
Species transport in porous media | Ribes | FLUENT | 7 | October 10, 2020 16:38 |
air flow over porous media | Ribes | FLUENT | 0 | September 18, 2016 05:11 |
Porous Region within Open Air "Wind Tunnel" Region Interfacing | pkirchner | STAR-CCM+ | 10 | March 27, 2014 19:10 |
Modeling air phase diffusion w radioactive decay | John Tauxe | Main CFD Forum | 0 | July 3, 2007 15:55 |
Species Transport Convergence | Emily | FLUENT | 0 | March 23, 2007 15:00 |
