Stream function contours on a 2d plane of a 3d geometry assuming Z component as zero |
August 21, 2017, 05:36 |
chirag khalde
Rep Power: 15 |
Dear All,
I am trying to compare 2d case (S-shaped ) and a 3d case (S- shaped with defined thickness). 2D: Stream function is available in 2D so I could get that! 3D: As stream function are 2d, I am trying to define a stream function on the cut plane where Z=0.5. I want to assume Z component as zero. I donot wish to use stream traces as they are in nature 3D. Please help! |
fluent, stream functions |
[swak4Foam] foam-extend-3.2 groovyBC example wont execute | JFM | OpenFOAM Community Contributions | 0 | June 17, 2016 10:32 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 15:07 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
stream contours in 3D geometry | satya | FLUENT | 5 | September 28, 2003 06:06 |
Mixing plane geometry definition | Hbet | FLUENT | 0 | January 18, 2002 08:16 |
