Effect of Mesh Density on 1 2D flow profile
Old   August 17, 2017, 05:58
Default Effect of Mesh Density on 1 2D flow profile
HINTERLAND
hinterland1 is on a distinguished road
Hi all, I have just created a simple 2-d case.
Inlet: 0.01m/s velocity inlet
Outlet: 0Pa pressure outlet
Walls: No Slip, Non Moving
Convergence criteria 1e-4
Now the thing is, I am using the same conditions, and varying the mesh density. I realised that the higher the mesh, the higher the deviation from a parabolic flow profile.
This is the compiled graph of the mesh density vs outlet flow profile.
What is happening here? Shouldn't a higher mesh density result in a higher accuracy (parabolic outlet flow) instead of a flat one?
hinterland1 is offline   Reply With Quote
Old   August 18, 2017, 01:46
Exclamation
HINTERLAND
Bump.
Does anyone actually know why this phenomenon is so???
Old   August 18, 2017, 05:05
Cees Haringa
CeesH is on a distinguished road
Is the velocity 0.1 (as mentioned in picture) or 0.01 m/s?
If it is 0.1, the entrance length of the flow is approx. 0.05*Re*velocity = 50 cm (Re = 1000), so your flow is not fully developed - hence the flattened profile at the exit.
CeesH is offline   Reply With Quote
Old   August 18, 2017, 12:08
Julio Mendez
juliom is on a distinguished road
Send a message via Skype™ to juliom
What makes you think it is wrong? What is the Reynolds number? What location are you using to take the profile? These should be the questions you might be asking yourself.
It seems that you are taking the profile at a location where the conditions are turbulent. Look at the wall the gradient looks steeper there.
juliom is offline   Reply With Quote
Old   August 18, 2017, 21:22
Lucky
What makes you think the parabolic profile is the answer? You have developing flow in a pipe. It's only parabolic once it is fully developed.
With increasing mesh density, you better resolve real gradients and have less numerical diffusion. Hence, with a better mesh you correctly get the non-parabolic profile. With a coarse mesh, the numerical diffusion increases causes the flow to false approach the parabolic profile faster.
Pressure Outlet Targeted Mass Flow Rate LuckyTran FLUENT 1 November 23, 2016 11:40
Dynamic Mesh problems - Bullet moving through a barrel and Muzzle Flow timclark11 FLUENT 0 April 4, 2015 11:02
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Mesh size for particulate flow simulations Shahri Main CFD Forum 0 March 24, 2009 18:40
