August 15, 2017, 02:42 |
Fluent mesh problem
Ray
Rep Power: 12 |
I currently face a workbench Fluent mesh problem. I used multizone, and I wanted to add inflation onto a thin wall structure (the air domain of a heat sink). The mesh shows successful. But each time when I use multizone, some faces are missing in Fluent mesh even though I still can see the mesh inside those faces. Then I try to proceed to Fluent setup, it showed error: aborted due to critical error. Anyone can tell me what the problem could be? Thanks in advance.
August 15, 2017, 04:17 |
Taiwan,new north city
Rep Power: 9 |
i think you better create hybrid mesh. try to find the problematic body and use different mesh type. then you will get it. multi zone mesh cannot be achieve all the time bcz of the model complexity.
fluent, mesh, multizone, workbench |
Problem with fluent mesh | edwardone333 | FLUENT | 0 | March 12, 2017 12:22 |
hybrid mesh created by pointwise fails mesh check in fluent due to left-handed faces | Hamid.de | Pointwise & Gridgen | 4 | November 9, 2016 12:20 |
FLUENT adding mesh nodes problem when importing 3D mesh from ICEM | guxin7005 | FLUENT | 2 | June 27, 2016 22:41 |
[ICEM] mesh quality problem in fluent | turbotel | ANSYS Meshing & Geometry | 0 | February 23, 2011 23:24 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
