Condensation with Thermal phase change model
Old   August 14, 2017, 00:29
Default Condensation with Thermal phase change model
haze_1986 is on a distinguished road
Hi guys,
I am trying to model condensation of a process flow over a long pipe, extracting constant heat flux over the whole length. I realised that, depending on the saturation temperature of the two phases, the lowest temperature it can ever go in the process is the saturation temperature. I would supposed when it becomes fully condensed (liquid phase = 1) it should still be able to fall below sat temp if I continue to remove heat from it. I am not sure if this is a bug since that liquid phase fraction at the most can reach 0.999999 but not 1. And is that what is preventing any reduction in temps further because of that small amount of gas still existing in the flow?
Any one face this issue as well?
Regards.
haze_1986 is offline   Reply With Quote
Fluent Limitations tymcme FLUENT 6 August 1, 2022 09:50
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Change phase phenomena Imane FLUENT 0 May 4, 2016 16:56
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
thermal phase change serdar CFX 3 May 3, 2005 07:50
