August 13, 2017, 15:22 |
coupled walls vs constant wall T
Yang
Rep Power: 11 |
I set up two geometries, one with a solid wire and fluid around the wire (a) and one with only the fluid (b).
(a) has wall BCs for the fluid and solid shadow, both at 2000K (temperature thermal condition). (b) has wall BC at 2000K (temperature thermal condition). Otherwise, both have the same setup. The sizes of the flowfields are slightly different but should be irrelevant for this situation. Yet, the thermal boundary layer (?) for (b) is much thicker than (a). Why is that? Is it possible to make these match? (a) temperature field (sliver at the bottom): http://imgur.com/Dy6fhto (b) temperature field: http://imgur.com/Rkbt1Qh |
August 13, 2017, 19:17 |
#2 | |
Lucky
Rep Power: 66 |
I really can't much sense of your pictures. Where the heck is the wire? Also, why are the top, right, & bottom boundaries at a temperature of 2000K? |
August 13, 2017, 19:30 |
Yang
Rep Power: 11 |
Thank you for your reply LuckyTran. Only the bottom is at 2000K for both. I guess the top and right are just outlined in red; their temperature is 300K (just checked). The thermal "boundary layer" of (a) is so thin it looks the same but it's 2000K.
August 14, 2017, 19:58 |
Yang
Rep Power: 11 |
Found the difference; I accidentally used "scalable wall function" in my viscous model which made the thermal BL much thinner, probably b/c it was scaling my already refined wall mesh?
coupled, temperature, wall boundary conditions |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 22:43 |
Is there a correlation for Nu number in laminar pipe flow with constant wall heat flu | Shomaz ul Haq | CFX | 5 | June 19, 2017 09:04 |
Reaction Rate constant at the wall | Diger | FLUENT | 0 | December 29, 2016 17:18 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Implementation of wall functions with a constant shear boundary condition | General_Gee | FLUENT | 0 | February 27, 2012 08:49 |
