Named selection body doesn't show up in Fluent Boundary conditions |
August 13, 2017, 12:25 |
I am new to CFD simulations, I am trying to do a wind turbine simulation. I drew the blades in gambit and import the file in Workbench design modeler. I then drew a cylinder (rotor) around the blades and englobed everything in a bigger cylinder representing the fluid (wind). I used Boolean to substract blades from rotor (without keeping the blades) and the rotor from the fluid (keeping the rotor). I meshed it and named all faces and bodies. In Fluent, boundary conditions, I find only parts related to the Fluid and contact-regions + some walls created by fluent. I can't find the rotor (faces or bodies). I need the rotor body in order to plot the moment, drag and lift forces to calculate the Cp. I will attach capture screens of the geometry, the named selections and boundary condition. Geometry : http://imgur.com/oFU8RYu Mesh and named selections : http://imgur.com/xRHgjiJ Boundary conditions: http://imgur.com/3Gmps0d Moment monitor: http://imgur.com/a57dQyf Last edited by Rhilane; August 13, 2017 at 12:35. Reason: The links to the screen captures don't seem to work |
August 13, 2017, 15:04 |
Yang
Rep Power: 11 |
What's "pales"? There are two surfaces b/w the rotor and the fluid in Mesh, one for the fluid and one for the rotor. Seems strange that you can calculate the moment without the blades...
August 13, 2017, 15:08 |
"Pales" are the blades (it's in french)
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 02:44 |
Problem with SIMPLEC-like finite volume channel flow boundary conditions | ghobold | Main CFD Forum | 3 | June 15, 2015 12:14 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 18:30 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
