August 9, 2017, 17:29 |
Vortex Rings Generated from low Re sphere
Adam Freund
Rep Power: 9 |
Hi all,
I am trying to model a 1um sphere with water flowing past it inside of a box, generating an Re of ~20. I would like to visualize the vortex rings that form as the fluid passes along the sphere. How would I go about structuring the simulation so that this can be measured? -Adam |
August 10, 2017, 11:08 |
Lucky
Rep Power: 66 |
There's no difference in the way you would run the simulation. At the end of the day, you get velocity at many (or every) time-step and you somehow must use this to visualize the vortex rings.
Unfortunately, flow visualization is not so straightforward. There's many different ways to do this, and I highly recommend doing your own lit search. Some people use isosurfaces of pressure, some use isosurfaces of vorticity, some use Q-criterion, some use lambda-2 criterion, some find complex eigenvalues, and so on and so on. The issue is that it's hard to come up with a precise definition of a vortex ring that everybody agrees to. |
cfd, fluent, vortex |
Possible to select Cells next to a SPHERE surface? | keepfit | OpenFOAM | 2 | November 30, 2016 15:47 |
[snappyHexMesh] Sphere in a channel by snappyHexMesh | arsalan.dryi | OpenFOAM Meshing & Mesh Conversion | 0 | November 14, 2016 16:01 |
OpenFOAM : flow around a sphere at low Reynold number | maxou1993 | OpenFOAM Running, Solving & CFD | 1 | July 7, 2015 05:13 |
Vortex generation with starccm+ | Benony | Siemens | 0 | May 17, 2006 11:59 |
Vortex Rings | Ozgur M Polat | Main CFD Forum | 5 | October 15, 1998 23:29 |
