sinusoidal airfoil oscillations
Old   August 3, 2017, 08:00
Default sinusoidal airfoil oscillations
flanag
lfla is on a distinguished road
Hi everyone!
I am studying 2D transient dynamic stall on a s809 as part of my masters and I was hoping for your assistance. I am using this formula to control the oscillations:
alpha(t)=alpha(0)+alpha(1)sin(2*pi*f*t). where alpha(0)=mean angle 8deg;
alpha(1)=5.5deg oscillation amplitude; f=1.2Hz; Ufreestream=30m/s
I have used the following interpreted udf and added it to the inner rotating domain under mesh motion.
#include <stdio.h>
#include <math.h>
#include "udf.h"
DEFINE_CG_MOTION(airfoil_pitch, dt, vel, omega, time, dtime)
real pitchampl, pitchdispl, omg, pi, count;
pi = 3.14159265;
/* reset velocities */
NV_S(vel, =, 0.0);
NV_S(omega, =, 0.0);
/* motion */
pitchampl = 5.5 * pi / 180; /* angular pitch amplitude */
omg = 2 * pi * 1.2; /* angular frequency */
pitchdispl = pitchampl * sin(omg * time); /* resultant displacement */
omega[2] = pitchampl * omg * cos(omg * time);
However this wont take into account the mean angle, has anyone done something similar. if this udf is correct perhaps i am inputting it incorrectly in the fluent gui.
so should i define the freestream at the inlet with respect to that mean angle ; Components >> x_vel=30cos8 and y_vel=30 sin8.
Also, how could i find what the angle of attack is for each time step?
Thanks in advance for any help.
P.S. If you would prefer to contact me via email instead of this thread please contact me at flanagl1@tcd.ie.
lfla is offline   Reply With Quote
Old   August 4, 2017, 11:42
Smile
flanag
Has anyone done something similar with dynamic stall modelling on an airfoil using fluent, do i also need to set a sinusThank youoidal osillating freestream?
Old   October 21, 2017, 09:46
Hanye Azimi
ronak is on a distinguished road
Have you overcome to the problem? Is the UDF correct?
ronak is offline   Reply With Quote
Old   October 21, 2017, 10:41
flanag
The udf is correct for defining the motion of the airfoil. First step is to interpret it and then apply it to the airfoil or to the domain depending on what you keep fixed.
Old   October 21, 2017, 11:17
Jaesan Yoon
litzj is on a distinguished road
how about using compiled instead of interpret
litzj is offline   Reply With Quote
Old   October 21, 2017, 15:04
Hanye Azimi
I want to have a motion for whole the domain, airfoil moves and rest the domain moves together. Actually I compiled this UDF but it seems that there is no motion,judging by the animation.
What do you think?
Old   October 21, 2017, 15:12
flanag
What do you think?
I'm not really sure why you want to rotate everything because in that case you wont represent the flow over a pitching airfoil unless you define your inlet according to a sinusoidal function. You should be able to preview the motion and the mesh you have used.
Old   October 22, 2017, 10:17
Hanye Azimi
I want whole the domain to move because of 2 reasons :
1- If the whole moves,the size of all cells would be the same and I wont have some cells with high A.R or bad skewness
2- I'm going to valid with the attached paper.( Dynamic Stall .... ) in this paper there is a pitching motion for whole the domain.
Old   October 22, 2017, 10:31
Jaesan Yoon
how about write full component of speed and angular speed?
vel[0]=0
omega[0]=0
omega[2]=what you want
Old   October 22, 2017, 10:34
Jaesan Yoon
or made motion at the dynamic mesh panel
without remesh or layering
Old   December 4, 2017, 03:27
Default pitch motion for domain
  #11
Hanye Azimi
Hi
I tried to simulate a pitch motion as I mentioned before in this thread. Although I tried several UDF, Ive been working on one of them at the momemt,a CG_MOTION one.
The UDF has been compiled correctly. The values are acceptable but the lift coefficient and drag coefficient plots are not harmonic. I wish to validate with this paper : 'Dynamic stall simulation of a pitching airfoil under unsteady freestream Velocity' . I attached some screenshots of simulating with Ansys.
It's best to know that :
freestream velocity=1.89
omega=0.37
rotation amplitite=15 deg
The point is that in this case it's going to move whole the domain
I'll appreciate if you take a look and tell me what is wrong of the process.
Old   July 18, 2018, 19:25
Mahdi Hasan
mahdihasan is on a distinguished road
Did it work? Was the motion harmonic? I have a similar type of UDF but my the body is rotating 360 degrees
mahdihasan is offline   Reply With Quote
Old   July 22, 2018, 04:54
Hanye Azimi
what kind of harmonic motion are you going to simulate?
airfoil pitching 2d
SU2 AOA optimization 454514566@qq.com SU2 9 March 7, 2022 17:17
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 13:42
High drag for airfoil compared to XFOIL and wind tunnel data Ry10 SU2 15 October 30, 2016 18:27
2D FFD Optimization RLangtry SU2 2 August 5, 2014 10:48
Problem with restart solution in shape_optimization.py robyTKD SU2 Shape Design 21 May 29, 2013 10:26
