Tanuj
Rep Power: 0 ![]() |
Hello, I made a CFD mesh using hypermesh to simulate heat transfer from flowing fluid across a pipe wall.
Components created are: -Steel pipe (solid) -fluid flowing inside (fluid) -ambient air outside (fluid, in the form of an enclosure) -inlet (inside fluid 1 surface end) -outlet (inside fluid other surface end) Since I am not quite experienced with Acusolve I chose to work in ANSYS Fluent. I exported meshed file in NASTRAN. Then imported it into Fluent. But in Fluent there are no boundary conditions as "Inlet" & "Outlet". Also certain unknown boundary condition parameters appeared, which I couldn't understand. I am hereby attaching the graphics window of Fluent for your considerations. Kindly, help me in knowing if the components I created in hypermesh aren't correct, do I need to create "Interfaces" too or anything I am missing which must be made to get desired boundary conditions in Fluent. In anticipation of positive reply. |
#2 | |
Kushal Puri
Rep Power: 12 ![]() |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 05:18 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
