Fluent FW-H Steady State Calculation
Old   July 28, 2017, 16:01
Default Fluent FW-H Steady State Calculation
Praveen Gambhir
praveengambhir16 is on a distinguished road
Hello there fellow CFDers!
I have been running a Fluent case of an single stage vane-axial fan, and wanted to implement the Ffowcs Williams-Hawkings acoustics module inside Fluent in order to predict aerodynamic fan pass noise. I am running a steady-state calculation with third order MUSCL discretization for momentum and energy, and PRESTO! for pressure (these were the solver settings which work the best for my case, as I have run these settings multiple times with good correlation). I have prescribed acoustic sources as the fan blades, and a reciever 0.2m away in the Z direction. I have read in the User manual that the reciever files should be initialized along with the solution, which I have done. However, when I am performing post-processing to obtain FFT data, Fluent is throwing an error. Should I run a transient case instead with the same settings?
Sincerely,
Praveen
TTI
praveengambhir16 is offline   Reply With Quote
aeroacoustics, aerodynamic noise, fluent, fw-h
plz help,urgent, vof model steady state Garima Chaudhary FLUENT 4 March 15, 2018 13:22
MRF steady state mixing time Swift FLUENT 0 August 11, 2016 06:14
Time step dependence of convergence behavior of steady state simulations in CFX Chander Main CFD Forum 5 December 23, 2013 06:31
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
steady state, laminar vof_model Garima Chaudhary FLUENT 0 May 24, 2007 04:11
