received a fatal signal (Segmentation fault) using udf to reading node coordinate
Old   July 28, 2017, 13:56
Default received a fatal signal (Segmentation fault) using udf to reading node coordinate
f.yn is on a distinguished road
hi
i wanted to see node coordinates so i wrote this udf:
#include "udf.h"
FILE *fout;
int n;
Node *v;
void Print_Thread_node_position(Domain *domain, int id)
face_t f;
Thread *t = Lookup_Thread(domain, id);
fprintf(fout,"thread id %d\n", id);
begin_f_loop(f, t)
f_node_loop(f, t, n)
v=F_NODE(f,t,n);
NODE_MARK(v) = 0;
end_f_loop(f, t);
begin_f_loop(f, t)
real pos_x;
real pos_y;
real pos_z;
pos_x = NODE_X(v);
pos_y = NODE_Y(v);
pos_z = NODE_Z(v);
if(NODE_MARK(v) == 0) /* if not already visited */
fprintf(fout, " f%g %g %g\n", pos_x, pos_y, pos_z);
NODE_MARK(v) = 1;
end_f_loop(f, t);
fprintf(fout, "\n");
DEFINE_ON_DEMAND(get_coords)
Domain *domain;
domain = Get_Domain(1);
fout = fopen("faces.out", "w");
Print_Thread_node_position(domain, 2);
Print_Thread_node_position(domain, 4);
fclose(fout);
but after executing i get this error:
Error: received a fatal signal (Segmentation fault).
can you tell me what's wrong?
f.yn is offline   Reply With Quote
Old   July 28, 2017, 16:55
i used <Message("")> there is a problem with this line:
Print_Thread_node_position(domain, );
Error: received a fatal signal (Segmentation fault). MayTheFlowBeWithYou FLUENT 12 June 30, 2017 04:09
Received a fatal signal (Segmentation fault) with UDF lisa_china Fluent UDF and Scheme Programming 2 June 30, 2017 04:07
fatal signal segmentation fault in a UDF hares FLUENT 6 January 21, 2017 04:26
Parallel UDF Segmentation fault error KevinZ09 Fluent UDF and Scheme Programming 1 January 9, 2017 06:30
Wave Tank Numerical Beach Error: received a fatal signal (Segmentation fault) Shyam Kaushik Fluent Multiphase 0 November 15, 2016 14:59
