comparison of stream function contours with a paper
Old   July 23, 2017, 08:12
Default comparison of stream function contours with a paper
mariam.sara is on a distinguished road
Hello I did run for Buoyancy square cavity flow heated from bottom wall I got good results about stream function contour and temperature but the problem my results for stream function were coincide with the results from other paper in shape but differ in values? The stream function contour at the paper of comparison has negative values while that I got from fluent all positive I check boundary conditions , fluid properties every thing look good? why my stream function results similar in shape while different in values? any advice please? The left photo from fluent and the other from the paper
mariam
mariam.sara is offline   Reply With Quote
Old   July 24, 2017, 05:44
Hello no one know how to answer me question?
mariam
Simple stream function vorticity formulation for flow past a rectangle [Matlab] a99 CFD Freelancers 0 March 1, 2016 22:36
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 11:20
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 07:59
