July 21, 2017, 20:12 |
Inviscid supersonic Flow
Abhinand
Rep Power: 10 |
Hello guys,
I have been trying to simulate supersonic flow over a flat plate in inviscid flow. But however I change my relaxation factor my residuals start to shoot up after some 600 iterations. I have checked the mesh and it has low skewness and good quality structured mesh Can you ease suggest ways to improve the convergence and solution controls if I have to change anything new Thanks very much |
July 22, 2017, 04:38 |
#2 | |
Kirill Borodin
Rep Power: 10 |
Can you please show the mesh and geometry? Which boundary conditions do you use? Did you turn on the energy equation? What EOS do you use? Sent from my Redmi Note 3 using CFD Online Forum mobile app |
July 23, 2017, 15:17 |
Abhinand
Rep Power: 10 |
Thanks for the reply,
My geometry is just a plain structured rectangular mesh BCS Inlet -pres inlet Outlet -farfield Plate - wall Other surfaces - symmetry Yes the energy equation is on I used pressure based solver since density based is going too much divergent Solution controls is all default intially with lower order scheme then higher order |
July 23, 2017, 17:04 |
#4 | |
Kirill Borodin
Rep Power: 10 |
OK, and what about the freestream parameters? You didn't answer the question about the equation of state For compressible cases (and your case is compressible) use density based solver, implicit scheme, ausm, Courant number ~ 1, green-gauss node-based and 1st order of approximation. Try this and don't forget to let me know about what I asked By the way, how do you initialize the problem? For initial values of flow parameters you should use the freestream values Sent from my Redmi Note 3 using CFD Online Forum mobile app |
July 24, 2017, 06:35 |
Abhinand
Rep Power: 10 |
Thank you very much for your reply. My free stream parameters are set to Mach 2.56 and gauge pressure of 1atm with operating conditions of 0Pa. Sorry I could not understand what you wanted to know my EOS. Can you explain a bit. I have used standard initialization and yes I initialized with freestream parameters only. (P_inlet) Here is a picture of my mesh. The middle domain is the portion where an injector is employed to inject into supersonic flow |
July 24, 2017, 07:09 |
#6 | |
Kirill Borodin
Rep Power: 10 |
Can you send the case file for me? Sent from my Redmi Note 3 using CFD Online Forum mobile app |
July 24, 2017, 07:13 |
Abhinand
Rep Power: 10 |
Yes, I used ideal gas only.
Can u tell me how to select solution controls depending on the problem. I tried with the settings yous said, the residuals keep on decreasing. What should I do to converge them |
July 24, 2017, 07:37 |
#8 | |
Kirill Borodin
Rep Power: 10 |
Looking through your case file can be useful. There is possibly a problem with mesh or boundary conditions. But I have 15th version of fluent Did you create your mesh via Pointwise? Sent from my Redmi Note 3 using CFD Online Forum mobile app |
July 24, 2017, 08:46 |
#9 |
Abhinand
Rep Power: 10 |
Yes, I created the mesh with pointwise. I have just a plain refined structural mesh. What could be the problems with the mesh that can happen?
BTW thank you, my solution converged. But isnt it advisable to move to higher order scheme to get better results? Can you tell me how to vary courant number as the solution progresses, what should we do if residuals starts to increase suddenly. What to do if it goes on a straight line? How do we proceed such situations Thank you very much for your timely help |
July 24, 2017, 14:20 |
#10 |
Kirill Borodin
Rep Power: 10 |
If you had no symmetry conditions, there would be problems in the stagnation point
You are welcome! Maybe it has sense in case of viscid flow for your problem. Higher orders are good for complicated geometries with separate flows You can increase it to accelerate convergence, but don't forget to save case and data. For each problem there is its own highest Courant number, and the precise value of it isn't obvious at all Sudden growth is OK when one changes a turbulence model or approximation order (in this case residuals level quickly reduces to the value it used to have before). But for a case when they jump several orders up high and the solution breaks down, then one should consider calculation control problems or mesh/geometry problems and even physical models that are used in the problem Sent from my Redmi Note 3 using CFD Online Forum mobile app |
July 27, 2017, 06:44 |
#11 |
Abhinand
Rep Power: 10 |
thanks for your reply.
I just have a small doubt. How do we be certain about the type of solver and scheme if we are solving a viscid flow. If the residuals are not decreasing as we think, how should we change the solver? For example, may I ask how did you know that Green gauss node based would work with implcit solver?. How do we determine that Many thanks |
July 27, 2017, 07:47 |
#12 |
Kirill Borodin
Rep Power: 10 |
Ausm gives precise solution of Riemann problem. Green-Gauss theorem calculates gradients of pointwise defined functions much better than least square method (the latter needs many points to achieve accuracy). Implicit scheme turns to be stable more often than explicit. That's why me and my colleagues use these parameters for hypersonic flows calculation
July 27, 2017, 07:54 |
#13 |
Abhinand
Rep Power: 10 |
Thanks a lot. The problem is Im continuing the same problem in viscous flow with a grid spacing according to y+ value and the free stream parameters. But when I run it, I find it very difficult to converge and changing none of the parameters seem to be changing the status of the residuals.
So for a start if I have used AUSM Implicit, Green gauss node based with courant number 0.96 after some 1000 iterations its starts to increase rather than oscillate between values. What should be my first step to make the residuals decrease and converge? Many thanks for your time |
July 27, 2017, 17:56 |
#14 |
Kirill Borodin
Rep Power: 10 |
For different problems residuals change in very different ways. Maybe for your problem a permanent growth is OK. Often in case of flow over blunt bodies residuals fall down very slowly. Play with Courant number - try increasing it by two or more times
July 27, 2017, 18:06 |
#15 |
Abhinand
Rep Power: 10 |
Yes I tried playing with the Courant numbers, initially I increased it and after sometime it started to detect divergence, so I reduced it back again.
If the residuals are exactly oscillating in a continuous fashion however you change your Courant numbers are they considered to be converged?? Thanks a ton for your help |
July 28, 2017, 03:21 |
#16 |
Kirill Borodin
Rep Power: 10 |
So find highest Courant number since which divergence doesn't take place
In case of hypersonic viscid flows residuals sometimes oscillate around a line that decreases very slowly (so the residuals also reduce in general). Try waiting for 10000 or more iterations Sent from my Redmi Note 3 using CFD Online Forum mobile app |
September 26, 2017, 00:30 |
#17 | |
Parag Mangave
Rep Power: 9 |
I have been trying to simulate flow over blunt bodies at Mach number 2 so my domain is rectangular with 10 infront of body 15 times backward and 10 times in up and below the body...Can you plz suggest the necessary bc for same for calculation of drag |
September 26, 2017, 01:53 |
#18 | |
Kirill Borodin
Rep Power: 10 |
September 26, 2017, 02:41 |
#19 | |
Parag Mangave
Rep Power: 9 |
September 26, 2017, 16:35 |
#20 |
Kirill Borodin
Rep Power: 10 |
1) For this type of the flow one should use computational region with inlet adapted to the shock wave (i.e. very close to it)
By the way, is attack angle = 0? If so, you need a 2D case, not 3D 2) I usually don't need to calculate flow over bottom area so I draw something like this. And do you? 3) Is your problem viscid or not? If viscid, your need inflation near the wall |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
Supersonic flow in a duct | ecto | STAR-CCM+ | 1 | July 6, 2017 13:00 |
[rhoCentralFoam] simulating compressible inviscid flow | Yuval | OpenFOAM Running, Solving & CFD | 2 | January 27, 2016 22:33 |
inviscid flow and turbulnces | sylvain | Main CFD Forum | 5 | August 2, 2013 17:48 |
supersonic flow at inlet and subsonic flow at outlet | deep | CFX | 3 | March 14, 2011 17:02 |
