Problem running Fluent in parallel
Old   July 17, 2017, 17:39
Default Problem running Fluent in parallel
Ryan. is on a distinguished road
I am trying to run a very simple case in parallel so I can make sure it works before running my actual simulation. In my journal file I only do a few iterations. When I run it in serial using "fluent 2ddp -g -i jet2.jou > ${OUTFILE}" in my script, I get the solution in a few seconds . However, when I run it in parallel using "fluent 2ddp -t2 -pnmpi cnf=$PBS_NODEFILE -g -i jet2.jou > ${OUTFILE}" it writes the following message to the log-file and the job continues to run until reaching the wall-time without solving the problem or giving any errors. I would appreciate it if you could help me find the problem. I am running this simulation in background on a Linux cluster.
Host spawning Node 0 on machine "l1439" (unix).
/apps/Ansys/15.0.7/v150/fluent/fluent15.0.7/bin/fluent -r15.0.7 2ddp -flux -node -alnamd64 -t24 -pethernet -mpi=pcmpi -mport 10.188.11.229:10.188.11.229:42773:0
Starting /apps/Ansys/15.0.7/v150/fluent/fluent15.0.7/multiport/mpi/lnamd64/pcmpi/bin/mpirun -e MPI_USE_MALLOPT_MMAP_MAX=0 -np 2 /apps/Ansys/15.0.7/v150/fluent/fluent15.0.7/lnamd64/2ddp_node/fluent_mpi.15.0.7 node -mpiw pcmpi -pic ethernet -mport 10.188.11.229:10.188.11.229:42773:0
Thanks in advance.
Ryan. is offline   Reply With Quote
Old   July 22, 2017, 02:47
Lucky
After this block, Fluent should print the list of nodes that it's running on. After that, it usually creates a cleanup script. If you don't see any text after this, that means Fluent was not able to start any processes and that's why it sits there and does nothing.
If you can run on your cluster in serial but not in parallel, then that means it's a problem in your mpi setup on the cluster. That's because the mpi itself is what starts the parallel Fluent processes on each node.
Old   August 11, 2017, 14:09
Thanks a lot. The problem was exactly the same as you described. Now, I'm using a different version and it works.
fluent, mpi, mpirun error, parallel, pbs
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 20:12
Problem running movingCylinders case in parallel with foam-extend-3.1 mhkenergy OpenFOAM Running, Solving & CFD 5 March 3, 2017 06:20
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
Fluent parallel license problem brothershuai Main CFD Forum 0 July 1, 2009 16:41
problem loading UDF in parallel fluent Tim FLUENT 12 July 12, 2008 13:59
