evaporation modelling
Old   July 15, 2017, 10:33
Default evaporation modelling
Abhishek Patil
abhishek_patil_06 is on a distinguished road
I need your suggestions in evaporation modelling.
In analysis, I'm injecting Brine solution into hot gases and want to check how much its evaporating water and giving back salt. For this, I used multiphase mixture model with 4 phases as air(primary), water, salt and vapor (all 3 secondary). In phases given phase interaction as water to vapor using evaporation-condensation model.
In boundary conditions mentioned volume fractions of each phase as i know it.
At outlet I want to check mass of vapor and salt.
I need your comments on case set-up mentioned above. Is this correct and efficient method if not please suggest other approaches.
Thank you.
abhishek_patil_06 is offline   Reply With Quote
Condensation and Evaporation modelling in Single Heat Exchanger Somnath rangrej Fluent Multiphase 1 August 14, 2015 06:53
Condensation and Evaporation modelling in Single Heat Exchanger Somnath rangrej Main CFD Forum 0 July 14, 2015 06:26
Evaporation heat loss modelling (water temperature below saturation)? ahmedmmx Main CFD Forum 0 June 17, 2015 19:37
Evaporation Modelling of a single droplet resting on a heated duct with air flow shashankmechguy Fluent Multiphase 0 June 11, 2015 11:46
DPM Modelling: Colloid droplet evaporation Meng Wai Woo FLUENT 1 August 1, 2007 01:27
