Investigating the conductive heat flow INSIDE a solid
Old   July 13, 2017, 09:15
Default Investigating the conductive heat flow INSIDE a solid
Mr.Tambourine is on a distinguished road
My problem is simple : I would like to define a plane tha tcuts across a solid, and monitor the heat flow going through this plane (i.e. inside the solid, and not on a wall)
I am quite confused as to how to achieve that with CFD-post...
The wall heat flow is available, but only between two different solids. Is it possible at all to investigate the flow inside one solid ?
Mr.Tambourine is offline   Reply With Quote
Old   July 13, 2017, 11:03
Onur Özcan
oozcan is on a distinguished road
send your model and clearly see what you would like to do
oozcan is offline   Reply With Quote
Old   July 13, 2017, 11:14
Sorry, this will not be possible for confidentiality issues.
Just imagine one box-shaped solid. In post-processing, I defined a a plane "slicing it in half".
I would like to know the heat flow going through this plane. The difficulty being that this plane is not a wall between solid.
Is this clear ?
Old   July 15, 2017, 21:26
Aureliano Sancho
SanchoBuendia is on a distinguished road
Maybe one way of you do this it's to create in DM the two solids (the two part of you model) and join how single body, selecting both and click with right button and join the bodies, it works.
SanchoBuendia is offline   Reply With Quote
Old   July 24, 2017, 03:46
Yes, that was the first thing i thought of to.
But it would be quite a tideous solution for me. It would actually imply to modify several geometries for me (different configurations), re-edit several meshes, and redo a lot of computations.
With no better solution, i will do that, but i was hoping to find an easier way...
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Thermally coupling 1D gas flow to 3D heat conduction in solid Pyotr CFX 5 March 6, 2017 22:46
[blockMesh] 3D laminar flow in a pipe with a solid object inside clint OpenFOAM Meshing & Mesh Conversion 1 November 28, 2016 13:45
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
