Can I change the variable in UDF via Fluent console or window without compiling?
Old   July 12, 2017, 23:15
Default Can I change the variable in UDF via Fluent console or window without compiling?
Sangwoo Kim
swtbkim is on a distinguished road
Hello all!
I want to change my variable used in UDF without re-compiling.
For example,
#include "udf.h"
#define const_min 10
DEFINE_ADJUST(UDF_name, domain)
real var_one;
var_one = const_min*5+2;
// main body //
I defined the constant, "const_min", and it is used in the body of my UDF.
I want to do kind of case study, varying const_min from 10 to, e.g., 100 (10, 11, 15, 20, 40, ..., 100)
For this, I should change the constant in the source code and repeat compiling.
Can I change this number in the Fluent window?
I think I can use some UDS for the variable, but I have no idea how I can do it practically.
Thank you all in advance.
Best regards
swtbkim is offline   Reply With Quote
About UDF compiling issues: 'nmake' Haoyin Shan Fluent UDF and Scheme Programming 15 November 4, 2019 19:05
Trouble with compiling UDFs in FLUENT cp703 Fluent UDF and Scheme Programming 28 June 1, 2018 04:22
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
Fluent UDF compiling error C1083 leizhao512 Fluent UDF and Scheme Programming 3 October 14, 2015 03:15
Why I have error compiling UDF with FLUENT12 while no error with Fluent 6.33? josh_z FLUENT 2 January 11, 2010 12:17
