July 12, 2017, 12:32 |
Having problems with mixed convection
Rep Power: 10 |
Hello, I have a project for studying the case of a concentric annulus with a moving core (2 concentric cylinders), through which the fluid flows. There is a gravitational field being exerted perpendicular to the axis of the cylinders. The inner cylinder is spinning at constant speed and there is a temperature difference between the two cylinders (the inner cylinder has a higher temperature.) I want to study the effects of mixed convection on temperature and velocity contours on various lengths in the tube.
The problem arises after I want to reach a solution. Firstly, the solution does not converge very easily. I have turned on gravity, set the density calculation method to Boussinesq, set operating temperatures, set the pressure discretization method to PRESTO! and I have a good structured, consistent mesh. After a while the solution doesn't meet the convergence criteria but rather the residuals reach a point and only fluctuate around one value, and also the result does not contain a clear effect of natural convection as the contours seem very symmetrical around the cylinders' axis except certain points, which go away after a certain length. How do I fix the convergence and the results? And how do I make sure the effect of convection is clearly seen? |
concentric annulus, convection, fluent, mixed convection, natural convection |
Fluent Mixed Convection Problem | cfdsolver1 | FLUENT | 7 | September 19, 2016 05:58 |
Convergence - Mixed Convection - Circular Cylinder | Aarthy Meena | FLUENT | 1 | August 16, 2016 13:31 |
mixed convection in triangular cavity | imipramine | FLUENT | 0 | January 21, 2013 05:33 |
solving mixed convection flows | tom | Main CFD Forum | 0 | October 30, 2008 15:08 |
problems in natural convection | nabeel | FLUENT | 19 | August 6, 2004 01:52 |
